MAF to test/buy
I am having an issue whih I have researched as being a potential MAF issue. Has anyone got one I can borrow to test or buy a known working OEM one please. Thank you again guys.
nip over and try one of mine if you wish
ย
The problem seems to have cured itself...if it happens again I sure will take you up on that offer. Thank you.
Sounds like a dodgy connection, take the connector off and give it a good clean up even if it appears to be clean.
ย
I will do, I think the heavy rain effected it. The car wouldnt rev past 5K in 4th...seems fine now.
Ah yes a soaked MAF would have that effect. It would be a good idea to install a splash shield below the filter to prevent it happening again.
ย
I do have one and forgot to put it back on last time I had the front apart for cleaning. Thank you, at least that confirmed what I had researched.
