Hi everyone, my '91 TT is reading error code 21 (ignition sensor circuit) or the PTU.. I'm sure this is quite a common problem experienced by lots of users and I apologise if there's threads I've missed.
I understand pre '92 models had an older version PTU which was prone to failing and was later replaced for a more reliable unit. My question is: is it a simple case of buying the newer replacement unit? I'm assuming I will need an adaptor harness also? Is there anything else I'm missing?
Thank you in advance.
Jay
Fot the PTU swap straightforward replacement Jay. Nissan part# 22020-97E25. Everything you need to do the swap.
https://conceptzperformance.com/nissan-oem-22020-97e25-power-transistor-unit-ptu-series-2-kit-nissan-300zx-90-96-z32_p_605.php
Also check harness connections PTU for damage and/or corrosion.
Edited by AndrewG
  • 1 month later...
hi what does customs charge when part has landed in uk ,
cheers
cheers
Depends on what CZP mark it down as.
Usually it will be 20% of the value and a handling fee.
hi thanks is CZP the best place or is there anyone in uk or on ebay i can buy from:thumbup1:
