Wheel fitment
Hello everyone
Thinking to buy new wheels for my Z 18 9,5j ET 18 all 4 z is still on standard suspension and my question is do I will need to roll the arches or that will be straight fit?
And as well where is the best place to buy bushes kit for front suspension ?
Thanks in advance
Yes, you will with that width, especially at the front.
Ideally a staggered fitment is best. Stick with the 9.5" for the rear, you'll want to be around ET35 for a flush fitment. For the fronts, generally go an inch narrower. So 8.5" would be best suited with an offset of ET20 or 25.
Nice one buddy thanks
Need to scrap that idea :(
Looks like you've been asking the same questions on the Nismo UK page - just for your recommendation, the information offered to you there is incorrect.
......unless you want to run stupid stretched tyres, but even then....and on stock suspension that's going to look appalling.
Yes mate I did ask question there just to find out what people are running
Today I went to have a look on the wheels 18 ET18 9,5 and 10,5 and on the rear
Wheel fits ok and front wheel was catching on callipers :( will need to use spacers
At least 15mm on the front which I don't want to do that so for now I'm scraping idea of new wheels
10.5 ET 18 at the rear most certainly will NOT fit without rubbing badly under compression, the same being said for the 9.5" et 18 at the front. Whilst you're up on 4x4 stock suspension status, they probably fit....until you drive the car and realise they rub and scrub over every bump in the road.
No need to scrap the idea of getting replacement wheels, just choose wheels with a favourable offset.
If you added 15mm spacers to a wheel with ET 18, that gives you ET3 effective and on a 9.5" wheel at the front, they'll be poking out into the next county.
