9.5 x 18" +10 offset on Front?
What would be required, or is it not possible, to get this size of wheel to fit up front? Having been reading old posts. A 9 x 18" +22 looks to be perfect and I know that this would make the wheel sit 19mm further out than that, so wondering if it can be done without running silly camber? Could the arches be rolled to accommodate or would it be more drastic bodywork mods?
That's actually a fairly decent spec for the front. You might have to play around with the arch liner tabs a little. You won't even need any nasty stretch on those. 245 or even a 255.
Thanks, I thought it may have been just a bit too big but having lost out on a set which were 9x18" + 22 this is the next best I could find that has a set of rears that will work. Looks like I will get these and hope that it is just a little bit of arch liner work as you say. Cheers
Just to double check you're going for +22 @ 9" at the fronts not +10 as +10 will require work.
+10 was the plan! Lost out on a +22 set.
  • 2 months later...
