front indicators not working. But rest are..
I noticed on starting the Zed for the first time in a fortnight that my front indicators were not working. As usual, I checked the bulbs, as it's on both sides, the relay, the indicator stalk and fuses. All seems OK. The hazards work fine and as normal, and on the fronts also which eliminates the bulbs being the issue, or corroded bulb holders. I also noticed that when I put the indicators on, it clicks twice as fast which may indicate a short somewhere, but where? Any ideas anyone? The back light indicators and side indicators also blink twice as fast. Something is not happy but what?
Indiators flashing fast is a current underload (ie bulb blown/not connected) and is the flasher units warning mode. As
all the lights flash when the hazzard switch is used that suggests engine room harness and bulb connectors are good
from the dash forwards. Were you working around the dash area recently? Check the connector to the indicator stalk
and local wiring. Any splices for aftermarket alarm system?
On the same loom are the side lights, and they work fine, as do the fogs. I have checked the indicator stalk and the looms that go into it, and they seem untampered with and original. It's got me foxed. If the side lights weren't working then I would know its the loom and a possible connection/short but since they are working fine, I can only assume it is something maybe inside the indicator stalk itself maybe?
All your indicator bulbs are the standard filament type ?
If not as Andrew says you have one blown or at least one is led type.
You have checked the relay you state, this is by the pedals ? If you use led signal bulbs this would be where you'd fit an aftermarket fast flash relay, thus eliminating the oe relays current sensing underload.
Had a look at the circuit diagram from the FSM EL-65 (which I have attached) to remind myself. You can see that before
connector M10 the indicator circuit is only routed Left and and Right through the Hazard and Indicator switches. It is only
after M10 that Left and Right is split into Front and Rear (connectors E106 and B4 respectively). More thinking required.
Yes more thinking required. I have no LED bulbs - all standard. So, it can only be something to do with the body ground or the connectors - as if the side lights work but the indicators are shorting/grounding or something else (to replicate a short) - it must be do with the wiring. Maybe a replacement loom from the connector is the way forward?
So a few hours tonight of further investigation and it is definitely the looms - corrosion I would imagine, as they were working before the winter. Anyone got any looms spare at all? They need to be able to accommodate twin filament bulbs rather than single filament ideally.
Also check for corrosion on the pins of the plugs in the passenger footwell, im not sure if the indicators are definitely routed that way, but many are including the horn and the headlights, so worth a look.
I never knew there would be connections in the footwell except for the fuse box there. Is there any pictures of where I should be looking (now it is dark and I will have to use my phone to see there!)?
There are somewhere lol, remove the kick panel they are just mounted on the bottom of the A pillar before it reaches the side of the glovebox, you cant miss them :thumbup1:
Edited by groover
Im not talking about the drivers side where the fuse board is, its the passenger side :thumbup:
I said i wasnt sure if the indicators rum down the passenger side, but when i had issues with the horn and headlamp staying, corrosion on two pins in the plugs in the passenger footwell were to blame.
Strange how the side repeaters work and not the front indicators as they are fed from the same engine bay harness post connection 106. Also they work with hazards on... the feed from the cabin to the engine room harness is the same regardless of hazards or indicators. Quite odd.
