The fuel lines on my zed are corroded and need replacing, ive seen some nylon tubing
People have used also stainless pipe
There is also one other pipe that goes to the carbon canister i believe behind the front bumper
Has anyone replaced theirs im taking about the hard pipesthat run from the fuel tank to the
Front of the car
When I did mine I just used kunifer pipe, the same as I used for my brakes. Still easy to work with, but good corrosion resistance and pretty cheap.
Looking at the pipes the brake line 3/16 is too thin for fuel and return looks like 8mm ish but yes kunifer is also an option
Think I used 10mm pipe for mine. Was a while ago tho so can't remember for sure, but I do remember that I ended up getting pipe slightly too big so fitting the rubber lines was quite difficult but it worked. I looked at other options but decided on kunifer in the end because it's so much easier to work with and cheaper when compared to stainless or nylon even.
