Lights and Bits
Here are some more parts for you.
Set of rear lights and centre panel , which illuminates, i'm sure (2 wires sneaking round the back) Light good condition, doesn't look like ever been fitted as no sign of black sealant. (may split) £80.00 Sold
Cruise control steering column switch. if you want to move the steering wheel buttons, say for an aftermarket wheel, This should do the job. £30.00 SOLD
Thats it for now, when i get the energy to walk to the shed, i'll look for some other bits.
Rich
Edited by Rev1Richie
Wow the cruise control steering column switch are rare, however is that not one for left hand drive ??
Jeff
If your breaking your zed do you have standard steering wheel what condition and would you sell??
Hi
I'm not sure, i was talking about the lights having no sealant, but heres a shot of the back anyway. it has a nissan stamp in the area under the circular toolin mark
Rich
Jeff
Jeff, hi. Well right or left, doesn't matter to me, i've positioned it in my spare car where the steering housing is exposed and it seemed to fit better on the right of the column, now i've always been a bit useful, so i would have used some locks and bolts etc to fit it in.
Cheer anyway
(if it is rare i might put the price up to a ton... so buy it quick.)
Rich
Cheer anyway
Rich
It certainly does matter, the indicator is on the rhs in a rhd car! So where on earth did you put it?! Can't just swap it to the left as it would be upside down :turned: got excited for a second, I would have had it if it was for a rhd
Trev, sorry mate my plan is to MOT the car and sell it as one, i may have the wheel from my spare car but it will have the cruise control buttons on it, ill have a look and see what i find
Rich
Chris, well it wasn't going to matter to me, all i was after was a cruise control switch/knob/lever so i could put an aftermarket wheel on. ill take some pictures of the exposed housing and where i was planning to place the switch, its up to you then, at least you'll have all the facts.
Regards
Rich
Scotty
you have pm
Rich
So there's no comeback for the op, the reverse panel does look like an Altia, the two wires need connecting to an inverter to increase the voltage and then to the cars sidelight circuit, this is not a problem but the chances are quite high the green illumination that's buried inside may not work.
Edited by phutumsch
So I will take the lot of rear lights please! As long as they are the light up ones :)
99ify them Will :)
Chris you can see from the pics that there is some room on the rhs of the column, now i'm not saying its perfect, but the whole thing needs some fettling, and some thought, but i do this kind of stuff all the time.
Rich
Rich
Did you try putting the cowl back over that?
Alic, hi. well you cant actually because as i said the part need fetling and fiting, it doesn't just drop in. If your not mechanically bised in your handiwork, its probably not for you,
Rich
