Ecu
Hi guys,
Just a quick one, how do I tell if my ECU has been chipped or upgraded?
The bloke I bought the car off didn't really know what had been done to it.
It has a Apexi Type R old type boost controller, and a device which he described as "afm enrichment", so I was guessing nout has been done in regards to twiddling with ECU setting ect?
Cheers!
Eddie
Easiest way that I know of is to plug it into Consult and read the chip data from there.
Thanks guys.
I don't know the difference between a stock EPROM and a socketed EPROM?
Plus where is the best place to get Consult software from?
Thanks guys.
The stock EPROM from the factory will be soldered into the PCB. The replacement EPROM will typically
be inserted into a PCB socket. The photos below show what you should be looking for.
