Hello guys, I had my Hicas-light that came on since a few weeks. It only came on when I drove my car on the highway for more than 5 minutes at speeds higher then 90 km/h. Fluid level had been topped up. No problems were found with conzult and neither in "self-test mode". The car didn't do this before. After a good thinking I tried to remember when it first happened and what was changed to the car then.
The last thing I changed was connecting the rear speakers. Normally, in the '90 model, there is a standard amplifier for the rear speakers in the back. The headunit amplifies the front speakers and a low-level signal is send to the back. Since the rear amplifier is gone in my car I thought, let's use the wires that go to the back to send the high-level signal to the rear speakers. Big mistake!
It took me a while to figure it out because monday I had to go somewhere and use my GPS. I decided to switch the radio off to hear the GPS and then the Hicas-light didn't came on. I thought it might have been a coinsidence and tried it on the way back. Again the Hicas-light didn't came on. I then disconnected everything from the radio and connected 1 thing at the time and went for a test everytime I connected something.
Since the rear speaker or not connected anymore, problem is solved. I don't say that this is the case everytime but consider it a probable cause in case you have a problem with the Hicas-ecu.
Mike
