Oil Pressure Sender
Hi all, been looking around for a while and decided to bite the bullet and just ask.... I am having low pressure issues in terms of when cold shows correct temp and then drops to 0 ish when warmed up. I have seen on here that you could try changing the sensor. Not being incredibly good at the mechanical stuff I cannot find a definitive image of what one looks like when out and on a table in front of me OR where abouts it is. I could also do with a bit of info on mechanical checking of the oil pressure. An idiots guide or image with a big damn arrow would be great too!! I know its a lot to ask but I will make it up to you all by attending a few meets when this badass is sorted! Thank you in advance. Steve
And its located 17741980203_medium.jpg on the drivers side of the engine
Just a note, unless you have an early z32 or early engine, the sensor is on the passenger side not the drivers side oil tree as in the picture above.
Jeff
Easiest way to remove is a crow foot 17 mm on an an extension bar to go over the top of the sensor, be prepared for a small amount of oil to leak out.
Edited by JeffTT
Cheers dude, gotta give it a go... makes you feel all manly if it works!!!
Really is a 5 minute job if you have done it before, jack the car up on the passenger side, secure and slide under with a torch so you can locate and undo it, have a rag ready to catch the drips, refit the new one by hand until tight and nip up with the tool.
Jeff
I thought the passenger side location was an NA and LHD thing Jeff rather than Early late. The port is there on in both positions for RH and LHD cars it's just that for TTs with the turbo and steering column in the way the LHD version doesn't fit and vice versa?
Jeff
Pretty sure his is an 89 if it makes a difference to where it is
It is an 89 TT BUT it has a 92-94 engine according to the motor factors.....if that makes a difference. I will have a look in both places. Thank you guys for your help.
Having changed more than I can remember over the years you can find them in both positions turbo and non turbo, import and left hand drive, my first zed back in 1994 which was a genuine 89 car was an import twin turbo and the sensor was on the drivers side oil tree location.
When fitting after market oil gauges the blanked oil tree location on twin turbo`s is often used for the new gauge sensor and fits ok, if the OP has a 92 - 94 engine it will be on the passenger side for sure, saying that motor factors are unlikely to know the difference and just going by application lists, which are mostly the same for early and late engines.
Jeff
Jeff
Excellent, ill have a root around see what I can see... you guys are ace, thanks.
Nothing like a bit of consistency then ey :lol:
Same with all cars... they like making our lives easy!
Yeh I guess,
Jeff
I've had 2 Zeds and change the sensor on both.
One an 89, the other a 93. Both had sensor on the passenger side. :)
  • 1 month later...
im glad i found this thread i have the same problem or even worse when driving home tonight got low oil pressure , thing is when i looked under bonnet i had oil spray on front of engine fan shroud and boost pipes i will have a proper look in morning , also noticed quite a bit of oil on drive , I'm hoping its ok :eek::eek:
Hi where can I buy sender from online etc ,
Got mine from Ebay mate and when I gave it to Lee for fitment he said it was ok. Check there dude.
This rings alarm bells. I think you need to proceed with caution here.
Engine oil in the position you mention is almost always cam end seals. Check link below of a tech thread of mine.
http://www.300zx.co.uk/forums/showthread.php?155569-Wet-oil-cambelt-covers-waring!&highlight=Cambelt
Plus this one
http://www.300zx.co.uk/forums/showthread.php?140182-Surprise-engine-oil-leak&highlight=Cambelt
Jeff
Edited by JeffTT
Plus this one
Jeff
Awesome thanks for link
Doe anyone knows by any chance what thread the pressure sender is? I would like to use the leftside for an aftermarket-oil-pressure gauge. It looks like 10x1,25 but not sure.
Oil pressure sender on 300zx are known to give trouble , sometimes if you get a small drill and drill out the inlet hole in the sender it fixes the problem.
http://www.twinturbo.net/nissan/300zx/forums/technical/view/1002701/18-bspt.html
