Sun damaged dash
My dash has all curled up due to heat damage right where the demister vents are next to the screen. Is this common? And do people generally need a new dash? I can't think of a way to fix it without replacing it
Jake
Yeah they generally do that. Both my cars have it, but it's not that big of a deal for me.
I've got one here next to me and personally I would take the dash out, put some glue under it and clamp it down to dry.
Okay cheers. The problem I have is I want to be able to fit the vent I bought from you and the space where it fits is misshaped! I'll have a look at it see what I can do
Hmm, mine weren't that bad. The lip just rose from under the edge of the vent but it still fits in.
Mine has come up a little on passenger side but mine will be coming out at some point so I can see what's going on
Here's what's going on lads
65637ab4e2c8cbb2e0494386eb8aef03.jpgec7a07fda4fdab8932d6a9234d72ac37.jpgb91f8bd41af4cb27178552964004f44c.jpg160da9263b59fc5bda0e5f36054b9735.jpg
You can see in the 2nd pic that the surface is supposed to be glued to the plastic, and should be right up against the edge where the brown stuff ends. This means that it doesn't just peel up but also back away from the top. In the last two you can see that when you glue it, you really need to stretch it then glue it so the vent sit nicely on it.
Yes Jake those are your vents. Are bring posted tomorrow.
