ok car been running nice so turned the boost up to 10psi was fueling fine afr was good. after a little run pulled over and the car started hunting pretty bad reving up and down near to a stall. go home done a few boost leak tests all good unplugged the maff still the same unplugged idle valve did the same and stalled. ran consult no codes its not missing just hunting but pretty bad. i know this is air leaks that cause this but cant find any this only happed like i said after turning the boost up any ideas were to go from here
