Help !! MOT failure......Polyurethane Steering Rack Mounting Car Bush Kit SPF2492K
http://www.ebay.co.uk/itm/SuperPro-Polyurethane-Steering-Rack-Mounting-Car-Bush-Kit-High-Quality-SPF2492K-/331509011613?fits=Model%3A300+ZX&hash=item4d2f7a149d:g:sVAAAOSwAPlXhJzC
Car failed the MOT today as apparently I need the steering rack bushes replaced. Whizzed through everything else.
Question. Will the ones advertised above fit a 1998 JDM TT?
MPN SPF2492K
Reference OE/OEM Number 5445-71L00, 5444-35F00
Never lists the 98 models but I'm guessing its the same as the 95 specs? Gotta get these brought and fitted in the next 10 days or cost of another re-test..... ;-(
Plus I am itching to drive her...... again.....and again....
pretty sure there all the same mate. and easy to change too :D im sure someone can second that there the same
Yes they should be fine, l don't know about the 'easy to fit' bit. They are easy to fit when the engine is out but a pita with the engine in and from underneath. Good luck with them.
One side is a doddle to fit, the other a PITA, but totally doable. I had to come up for air a few times and throw some tools around to let of steam, but got there in the end! :)
If you struggle to get some, I have a set of energy suspension bushes in the garage that you can have and replace at your leisure.
Nice one Joely, thanks mate, I have just ordered some off ebay for delivery Friday and hope to have them fitted on Monday,
really nice of you to offer though, thank you man, its appreciated.
Thanks to all for your advice chaps, much appreciated.
