hi all needed some advice fuel pump not getting any earth signal so I change the fuel control module / relay/ fuse still now look car wont start but if I earth the pump car starts any one have any idea what it could be also If I leave the earth on the pump with a switch will that be safe thanks all in advance
Edited by 300zx aly
Hi when you put an earth to the pump can you hear it work straight away or only when the key is turned.
2002 Porsche C2 996 3.6
1991 Nissan 300zx TT Project
1997 Jaguar XK8 Scraped ☹️
You can earth it temporarily till you find the bad earth connection.
not my day today fixed the earthing problem with a switch took it out for a drive all going well than I dicided to be a smart ass drove it little hard with a burn out now I got oil leaking from the gear box quite bad drove it home with out any issues went in to all the gears fine I started it up again now I can hear noise coming from the gear box is that because its low on oil any one have any idea what the leak/noise could be .
bit like a crunching noise didn't have it running for too long will check tomorrow just wanted to get heads up things to expect or look out for
If I'm honest I wouldn't run it until you jack it up, see where the leak is and get some oil back in. Running it with low/no oil will shred the guts out of it.
leaks .. input shaft seal/ gasket out put shaft seal cracks or maybe it had a loop on on were the oil cooler was if its looped it could have came off and this will make all the oil come out.
ok guys found out what the leak was it was oil cooler adaptor come lose fix that back up fill the car with oil and now its running fine with one little issue am getting white smoke from the engine driver side back bottom don't now what it is
Heavy white smoke? And coolant is still clean?
Is it not the residual oil from where your oil cooled adapter was leaking? That would be about the right area.
that's what am thinking lets hope it is just that I did take it around the block it drove fine all the gauges seem normal
Personally I would give it a good run to clean any residue out of the system. Then if problem still occurs then start checking further things.
the smoke come through the bonnet near the break master cylinder
Was this straight after you started the engine or once you'd been driving. If it only happened whenthe engine was warm it might just be oil residue evaporating off as Stephen said
Edited by Alic
Why not do a proper job and get under there, clean and inspect. You won't get it all off particularly if your exhaust is old and rusty. But your going to reduce it. A little oil goes a long way, smoke wise.
