Alright... just had my timing done and car runs 10 times sweeter. However...
I have hunting idle which I have had for a bit now. I thought it would be something to do with the timing but it's not.
The boost gauge on cold engine on idle is reading the second line from the -7 which I think that's too close to the middle than it ever halls done before.
There is little smoke from the exhausts but not much. When driving there is no smoke and hot idle no smoke either.
What could this be? I'm after a range of different answers here :)
Thankyou
AFAIK that vacuum is a bit low so I would start with a boost leak test, then maybe compression test if that doesn't bring anything up
Yeah. The clutch and brake booster hoses were split slightly. Changed then and it's a bit better but not 100 percent
Get it hooked up to Conzult, and get the sensors checked plus a power test, that should give you a good indication of whats working properly and engine health.
A poorly MAF can cause poor idle.
You asked for a range of answers....:)
I was after a wide range of answers ;)
Strong spark?
I do believe so mate. But it's something to check... no problems at high rpm... just idle
Right just to let people know. The problem with hunting idle is sorted. Was the clutch booster pipe and stuff. Sorted now.
However I have white smoke which smells like fuel coming from the drivers side exhaust... passenger one is sound. Could this be a injector problem? They are only about 3 year old though
