UK TT speedo adjustment
okay , I now have a set of UK clocks , ( thanks to Mondo), now the UK clocks have 2 potentiometers that can be used for adjustment, does anyone know which one does what.? or where to find a guide on adjustment.
Ta
Sayers
Uk clocks should fit straight in without any need to adjust anything.
Jeff
Hi Jeff, I have a NA rear axle and a TT manual gearbox but an auto ECU, I thought this combination meant it would be out on the speedo ??
Yes I guess non turbo diff will make it read wrong, fitting an n/a speed sensor would correct it though.
Jeff
Which is easier, fitting a NA Speed sensor, or turning the potentiometers on the Speedo, ?? how much is a NA speed sensor ? anyone got one ? or back to the original , does anyone know how to use the potentiometers to correctly adjust for different speeds ?
for a NA diff you won't be able to adjust enough with the potentiometer method if the cluster is still standard (you will need to modify the cluster by replacing a couple of resistors with different values)
The potentiometer can only be used for fairly small adjustments if you still want it to show precise speeds over the whole range.
So, unless you have the electronic equipment to modify and re-calibrate the speedometer, the easiest way is to fit a NA speedsensor (actually you only need to swap the speedsensor-gears)
If you don't have the NA gear, you can order one here: https://conceptzperformance.com/nissan-oem-300zx-speed-sensor-gear-pinion-manual-non-turbo-32743-30p20_p_2536.php
NB: if you have two potentiometers on the cluster, then one is for offset-adjustment and the other for range-adjustment
if you need some information on how to (electronically) modify the speedo : http://tech.aus300zx.com/idial_install/recalibration.pdf
this is pdf shows how to modify the speedo for a wider range (eg. max 300kmh), modifying it for a NA diff is the opposite, but similar (lower range, max 260 kmh), so you only need to figure out the correct resistor value
I am looking for accuracy up to a ton. Will I get enough adjustment by using the standard clockswith 2 potentiometers ?
I thought you couldnt fit a na sensor in a tt box? The na sensor cog is smaller, so wouldnt touch the box cog, unless someone has designed a relocation bracket?
When i put a tt box in my na this was the case. So i bought an adjustable speedo converter. You fit it, drive , note speed on speedo and on sat nav, look up provided chart and enter value into converter
[sIGPIC][/sIGPIC]
maybe you are confused with an auto box ?
NA/TT Manual transmissions are identical apart from small differences in bellhousing
you may be able to get it somewhat accurate from 0-70 mph using the potentiometers, but the faster you go the higher the deviation from actual speed. (speedo will read more then actual speed)
