Cat Over Temp Sensor
Took Car for a spin
In storage more or less since 2009. Have only driven it a handful of times since.
Power failure after a few miles and Cat over temp sensor came on, got car home but smoke from engine bay and right exhaust
Thinking its Coil failure possibly x 2 spilling un-burnt fuel on Cats??
Nervous to drive it to mechanic
94SWBTT Slicktop
most likely be the cats are failing or blocked from falling apart inside m8
you got few options
replace with new
replace with Decats
or on the cheap if the pipes are ok take out whats left of the filter inside
decat pipes would be my recommendation
mark
Did you have a misfire (engine feel rough with vibrations) at the time ?
if so, more than likely caused by misfire, resulting in un-combusted fuel burning in the Cats. You'll need to trace the fault which could be from the PTU, Coilpack, or any of the connectors and wiring inbetween.
This. You need to ensure the basics are correct first. This may be of use for you to read;
http://twinturbo.net/nissan/300zx/forums/technical/view/922678/The-6-Ps-Proper-Preparation-Prevents-Piss-Poor-Performancegt.html
^^^^^^^^^^^^^ yup,will be misfire for sure
