ECU Guru Help
Hey guys, I just installed a later model ECU into my Z and though everything is working fine so far, I just noticed the potentiometer you turn to check error codes is pointing downwards towards the right. My old ECU had it pointing upwards towards the right.
I have looked up some info on which mode this is set to at the moment but I don't really know which way the potentiometer should be pointing to for normal mode.
Any ideas what this is set to?
Codes under Mode II
11: crank angle sensor circuit
12*: air flow meter circuit
13*: engine coolant temp. sensor circuit
14*: vehicle speed sensor circuit
21: ignition signal circuit
26*: boost pressure sensor
31*: ECU
32*: EGR function
33*: exhaust gas sensor circuit (left)
34: detonation sensor circuit
35*: exhaust gas temp. sensor circuit
42: fuel temp. sensor circuit
43*: throttle position sensor circuit
45*: injector leak
51*: injector circuit
53*: exhaust gas sensor circuit (right)
54: signal circuit from A/T control to ECU
55: NO malfunctions in the above
* indicates that the “Check Engine” light will come on under normal driving.
8. Turn the screw fully clockwise, wait 2 seconds, and turn back fully counter-clockwise to exit Mode II and return to Mode I.
To check O2 sensors
1. While in Mode II, start the engine and warm the engine up.
2. The ECU is now checking the left O2 sensor. Run the engine at 2000rpms for 2 minutes and watch the “Check Engine” light. The light should be blinking constantly.
3. To check the right O2 sensor, turn the screw on the ECU fully clockwise, wait 2 seconds, and then turn back fully counter-clockwise, the ECU will now be checking the right O2 sensor. Run the engine at 2000rpms for 2 minutes while watching the “Check Engine” light. As before, the light should be blinking constantly.
4. The light indicates the signal from the O2 sensor to the ECU. When the light is ON, it is rich. When the light is OFF, it is lean. It should be blinking, which means it is constantly switching between rich and lean. If the light is not constantly blinking, there is something wrong and will require further investigation.
5. Turn the screw on the ECU full clockwise, wait 2 seconds, and turn back fully counter-clockwise. The ECU will be back in Mode I.
I appreciate the reply but i dont need to check codes i have consult. What i need to know is the ecu looking like its set to mode 1 or mode 2 in that photo.
