I'm moving out of my current unit so will be having a bit of a clearout to make the move easier.
I also have two NA LWB breakers currently in which will be going to the big Z scrapyard in the sky before the end of the month. Panel cuts available if anyone needs a repair panel.
If there's anything you need just ask, piles of trims, engine parts, wheels, body panels, you name it it's probably here, some aftermarket stuff too.
  • Replies 38
  • Views 778
Hi Baz
I will take those two rear sections as discussed on ebay matey, will require a few more bits too
thanks
Dewi
Hi Baz, I don't suppose you have a pair of good condition rubber door seals.....
The ones that go round the entire door and wing mirror and between the window glass and sail panel?
I am also after both the rear quarter glass as mine have the rubber seal perished where they meet the body trim strip?
The front metal braces that go from the inner wing to the bumper, inside the front wheel arch? I have none to show what I mean....
Front TT inner wheel arch with the vents.... complete units?
Radio surround thin plastic strip that covers the screw holes hove radio....?
Good condition O/S folding wing mirror that isn't like mine and all floppy?
Both N/S and O/S door handles with good locks and good condition clear rings in them around the lock barrels?
2+2 boot carpet in good condition?
Rear quarter interior trim panels..... need the top black section to be in good condition?
There maybe a few more things I think of..... lol
Hi Baz
looking at N/S door mounted seat belt ( that retracts properly ) if both side good then I will have the O/S as well and front wing repeater bulb holder with wiring to splice ( x 4 )
Need a couple of S1 rear quarter upper trim panels (the black parts). If you have some that are mint (no peeling) then I'll have them, but I'll also take some crap ones and will get them re-trimmed professionally. So either/or.
Stop copying me........ lol......
Hi Baz
thanks
Dewi
Hi Dewi, I've emailed you.
Alright has.
How much would you be looking for the rear subframe with diff and rear end of the drive shaft?
Sorry mate ones sold the other is destined for my TT... lol
Baz after front bumper if you have one
Hi James, only one I have is a black NA bumper with a custom splitter on, I'll take a photo later for you.
have you got uprated injectors/tubs?/double din dash cheers ryan
Sorry Ryan can't help with those
hi baz
I'm after drivers side door handle with plastic clips ect. in black if poss.
thanks
trev.
Baz... Do either of your breakers have OEM exhausts...im after the 4 x chrome tips please
Sorry Gary no OEM exhaust tips (both had aftermarket systems)
Have you got any adjustable rear camber arms?
No rears unfortunately only got front aftermarket arms
Hi Baz, don’t suppose you have one of the little rubber stoppers that the bonnet rests on, circled in the picture. Mine has disintegrated.
[ATTACH=CONFIG]100210[/ATTACH]
Just buy new, they really are not expensive.
Have you got a block connector that plugs into the drivers seat you can cut off please? (Male connector)
Yes Ali but send me a picture of the female plug as there's different sorts
Yes mate I have some in good condition. PM me if you want one:)
