rear speakers not working help
my rear speakers dont work there stock ones i just replaced them with new ones still dont work have just fitted new ones in the front there ok and the stock ones worked to before i replaced them so the problem is the rear were do i go from here not really up in wiring not my thing atall so need to help here
Have you plugged your old speakers back in to see if they still work?
since i had the car the rear have never worked the stock ones dont work and the new ones dont work
i see there is a clarion amp on the left hand side is this amp just for the rear speaks or does it run the front and rear speakers
Have you checked your system settings? could be that you have all the volume set to front speakers and none to the rear.
Similar to left and right balance for example.
yes tried that its a new head unit but even with the stock head unit the rears didnt work
i have removed the stock rear amp and wired it in direct to the head unit using the own wiring that ran to the amp so rear speaks are working now
I was going to say, after fitting an aftermarket head unit, the connector lead from Nissan to ISO does not have a live feed to the OEM rear amp. You have two choices to rectify it....
....That is one of them! The other is to join the live feed for the accessory (eg electric aerial) to the one for the amp; and then you can still use the OEM rear amp.
You can add the missing lead into the connector and attach it to the amplifier output wire from the head unit..... Had to do it to my Audi to power the aerial amplifier....
A good car audio shop should be able to work out which wire powers the amplifier and use the amplifier / aerial trigger wire from the head unit to trigger the amplifier.
i think the amp was not working it didnt work with the stock head unit i have just got rid of it now all sorted
