With my insurance and tax coming to an end next month, it's almost surgery time. The car will be getting the full 200K service with genuine parts.
Aside from the usual parts you'd find in the 200K service kit, what else is worth doing while there's access?
Do you mean 120k? I.e all the pumps etc?
In miles, yes. Belts, tensioner, water pump - all of that stuff.
How far do you want or are you willing to go? What have you already got planned?
So far my shopping list looks like this, but I'm willing to spend another €100-€200 for anything that will be convenient to do at the same time.
Nissan OEM 300ZX Timing Belt Z32
Nissan OEM 300ZX Timing Belt Tensioner Z32
Nissan OEM 300ZX Water Pump 90-96 Z32
Nissan OEM 300ZX Coolant Bypass Hose Z32
Nissan OEM 300ZX Lower Idler Pulley LH Bottom Z32
Nissan OEM 300ZX Idler Center Upper Pulley Top Z32
Nissan OEM 300ZX Oil Pump Gasket Z32 (is this even worth doing? Just added it as it's cheap)
Nissan OEM Belt - Alternator NA Z32
Nissan OEM 300ZX Belt - A/C Z32 TT / NA or Alternator Overdrive Water Pump Pulley Z32
Nissan OEM 300ZX Belt - Power Steering 90-96 NA / 94-96 TT or Unorthodox Racing UR Power Steering V2 Z32
depending on (known) maintenance history:
-engine oil
-transmission oil
-differential oil
-brake fluid
-fuelfilter
-sparkplugs
-airfilter
-brakepads/discs
-check/replace coolant (needed anyway when doing timing belt)
http://300zx-twinturbo.com/cgi-bin/manual.cgi?list=ma&slide=8
Aside from coolant and brake fluid, all of those have been done recently. Spark plugs are worth checking I guess. I was thinking of getting all new brake pads soon, so the fluid can be done with those :)
  • 3 months later...
Won't have the garage space for probably another few months, so I'm looking at what else I can buy. Is it worth replacing the oil pump at 131,000 KM and 17 years? €200 isn't too bad and it looks like access will be reasonable with the other work.
  • 2 months later...
