Help please power windows not working
Hi all I'm new on here. Brought my first z32 n/a and got to say well chuffed with my choice to own an Zed. Have a few issues I'm working through got sold a bit of a lemon but hay I traveled to Belfast had flights and ferrey booked so wasn't coming home without the car. I'm making progress though and want it all sorted ASAP. My big issue is with the electric Windows
I have no windows working, iv changed the amp still no joy, motor makes no noise at all. I have power in one wire to the motor and power in one wire to the amp but no power to the switch. Can anyone please help or advise me on where to go from here, the bloke I got it off said it was just a fuse gone but if it was the fuse surly I would have no power and also my electric seats all work it's frying my head and I just want it working so I can put her back together.
Any advise would be much appreciated
Which switch are you using? Just check you haven't accidently depressed the window-lock switch....
No tried the isolation switch on the drivers side I assume that's the only one? When I have removed the switch there is no power in the connector block, anyone know of switch has to be connected to get power. I can only assume it's either both motors gone or switch any clues
From what i recall, the window amp controls both windows, drivers switch completes the loop. Take the switch apart, only 4 plastic lugs and see if there is anything obvious on the board below the switch track and check for dry solder on the pins part.
Check out B48-49 in the colour wiring diagrams
http://www.300zx.co.uk/forums/attachment.php?attachmentid=89377&d=1438023474
Edited by groover
Cheers will have a look and take some more bits apart tommorow and get back to you cheers
Thank you for the advise, I have checked the switch all looks good. Done some more testing I have 12 v to the amp on one wire but doesn't seem to be anything else live ( would have thought would have 12v in and 12v out ) 12 v to the seat belt and 12 v to the central locking but nothing to switch or motor any ideas anyone. I thought amp would be at fault but I have changed it and it's apparently a tested one so should be working
Is the fuse ok (kickpanel, bottom row, 3rd from the left, 15A -> EPS/HICAS)
are the motors working ? (just connect 12v to them and window should be going up or down)
Fuses all ok plugged window into a 12v car battery and it was working just fine any idea where the fault is?
Silver in a g plate standard wheels and body kit with a fro t bumper that needs ripping off and throwing on a skip lol, do t k ow how to post pics
Never seen any silver Z's around Belfast but there was one on gumtree a month ago with a bodykit 1990 TT 80k with 18" alloys priced at £2500 again never seen this one either.
She was on gumtree but not a TT or on 18s but was a month or so ago now, still no joy with the bloody Windows
So update and a head f**k got another amp and new switch and still not working both windows dead, put power to the motor via battery and Windows went up and down I still have 1 12 v green and yellow wore to the amp and to the central locking and to the seat belt but windows will not work no power to switch and when amp is plugged in still only one wire with 12v any ideas anyone please this is doing my head in
Have you looked at the link in my post 6? it shows the block that contain the feed for the windows
No o haven't to be honest I thought with having power to the amp etc that all that would be ok will have to pull it apart
Let me know if you need to try any more bits in it James!
