Hi
This is pretty much as the title states, the air will not blow out of the drivers side door. If there is a common fault or if anyone knows a potential issue with this that would be appreciated.
The car is a daily and i don't fancy opening a can of worms and driving to work in a mess of wires and panels
Chris
It's not that complicated to get in there. You only need to take off the panel underneath the steering wheel, held on by a few bolts at the bottom, and two in the middle I recall. The duct should be pretty obvious after that.
Edited by Alic
Some of the ducting might be either missing, dislodged or not put together correctly above the pedals.
As simple as that? I take it the pipe above the pedals goes straight to the fan?
Sorted it, thankyou for your help.
Someone has obviously had it apart before and not put it back right. The end of the ducting was all folded in on itself, blocking the passageway.
