Looking for a 93 TT offside fog light
I am trying to buy a front offside fog light to fit my 93 TT.
Is your car a S1 or S2..seat belts on door (S1) seat belts on body (S2). The reason i ask is the S2 had different lense patten from earlier model,btw welcome to the forum matey:)
Hi Znut, thank you for getting back to me. My belts are on the rear seat window panels, however the fog lights are being fitted to a very modified front. I got the nearside light off e-bay and the light came off a 32 1990 tt. Will that give you any clarity of what I am after. Many thanks Regards Steve
pic will be better mate of what you have now and ile be able to tell you what type you need to match
$_57
Hi having problems getting the picture onto the reply, it asks for the url? If it will help, the lens glass has ICHIKOH 21031. The lens has a main glass and the 2 ends are plastic. Sorry to bit into your time.
Regards and thanks
Steve
$_57
Regards and thanks
Steve
http://www.300zx.co.uk/forums/showthread.php?183453-Upload-images-for-Non-Subscribed-members
Use image hosting site like photobucket or imgur
Hi Alic
Can you explain like you are talking to someone who does not understand the guidance you have kindly given, because it all latin to me I am still working on cut an past.
Best wishes
Steve
Hi Alic
Best wishes
Steve
Haha, no problem. Have you got an account on imgur/photobucket/anywhere you can upload photos online to?
Hi Alic
WHAT? I have a plastic buket, as you can see computors other than for work powerpoints is not my strong point. I will research what you are advising and get back to you.
Steve
Hi Alic
Steve
https://secure.photobucket.com/register
Register for it. Click upload and drag your pictures into it.
Or if you want to make it easier for yourself you can subscribe to the forum and upload images on here :wink:
Did you get this sorted? If not I have a pair of fog's from a 1990 tt up for grabs
Also got the large mounting piece that goes across the front slam panel.. Complete or just fog's.. It's your choice..
Edited by NemesizX
Thank you for contacting me. I did get the fog lights but when you mentioned the large mounting piece is that the mounting to support a large intercooler rad, if so I would be very interested.
Regards and thanks
Steve
I'm not 100% sure to be honest. It's a large hard plastic part that bolts on to the front of the chassis and it houses the fog lights. It does look like there has been a small portion cut away to allow the fitment of a large front mount intercooler but I'm uncertain if this is what you think it might be?
I can get a photo of it and show you the part as it is off the car now. The fog lights were set inside it and bolted on with three nuts to the rear of the panel.
I believe this is an oem part Steve.
Here is an image of the part I have it's the part that houses the fog lights mate.._20160531_230227.JPG
As I say I do think it's oem and its part of the bumper support.
Someone correct me if i'm wrong, but I have the same model as your breaker and it comes with a single fibreglass piece that goes the whole width. that white one has detachable plastic bits on a metal frame.
Mine is like this, I think the white one is a USDM bar, I don't know if the uk one is different than this JDM one.
Edited by Alic
Yes Alic, you're correct, that is the part.
I didn't have a photo of mine as I'm 150 miles away parked in in a lorry.. So I Google the part and used the image there as it looks identical but as you say, this is white and usdm..
I was just looking for a way to describe it.. Lol..
The one I have has had the bottom inner corners removed to allow for a fmic to be installed, or at least that's my assumption
However the car did have the original ic's still mounted in it but have now been removed and are winging their way to the new owner
