What mods do you have?
A TT will gain more of a benefit IMO, but if you have some breather mods already you might bet a bit more grunt
Edited by Alic
I can't think of much benefit on a standard engine, aside from removing the speed limiter.
Isn't that in the clocks?
There is an Apexi exhaust, need the cats as it's 99spec planning an Apexi or Blitz sus kit.
Actually, yes, it does make quite a noticable difference.
Agree it improves driveability and makes for a slightly more responsive throttle, downsides? well non ! I fitted eproms to countless non turbo zed`s in my days and is very worth while, and I said don`t be looking for BHP increase because you looking at the wrong place its all about response and mild torque increases, oh and removes top speed limiter too.
Jeff
I have a chipped NA ecu, its quite aggressive though apparently as the vvt comes in at higher revs than standard, but does extend the rev limiter and with everything lightened and single prop, made it a livelier drive and felt a real difference in the higher rev band than when it was standard.
Jeff
That's exactly what I'm looking for Jeff, thanks.
