To save time when back in uk.
I have to replace this hose (which I have)
Got access to the top part of hose that goes onto the pump.
& new copper compression washers.
My help/advice is;
What is required to fit the lower part of hose?
It looks to be a screw type of attachment.
Do I need to remove anything from under the car.
Is there a seal for the bottom part of the hose?
Any one change this hose before as it seems a common problem!
Art
only couple of bolts that are part of the brackets that hold the pipe ..
other than that u need 17mm and 14mm spanners for the join on the very end of it
