Does anyone have an ifea what this thick green wires are for? They hav been shorted. Guess the where initially connected to the fusebox near the battery.
Looks like the fusible link from the small fuse box near the brake master cylinder on a right hand drive car, i take it yours is a left hand drive? Although the wires look too thick for that.
Check the fuse box in front of your battery, take off cover and see if the fuseable link is there
Is the fusible link a blue thick wire on the left of the fusebox? If so, yes it is. What could this 2 thick green wires ( +/- 4mm2) be? I already checked the wire diagrams in the manual but can't find it.
Ive never seen it to be honest, you will have to trace it back to see anything obvious, it may also be the inhibitor bypass, if you had a manual conversion in the past, this would normally be in the arch liner
Is there anybody withe a TT automatic who just can open hid hood and try to look for this wires and se where they are going. They were definatly not connected to the fusebox next to the battery (LHD)
Thanks, Mike
