Bose speakers
So when I drive my car (left hand side steering wheel I live in Canada) there is random radio noise on the left no words just weird radio sounds and it's only on the drivers side speaker the 2 back and the passenger speaker doesn't make any sound does this mean I have a busted speaker or does it mean it's the radio itself I bought the car not to long ago and it had a new radio in it could it be the wires are sort of disconnected
One of two things can be happening here.
1. Whomever installed the radio did not make the the appropriate connections and there is a loose ground for that speaker, causing it to buzz or make the weird noise.
2. Whoever installed the radio did not bypass the factory amp and it has now failed causing to make the strange noise on that speaker only.
I would check the wiring first and then jump to the speaker.
K cause new speakers in the front alone are like $1000-2500 and I can't even find back speakers
I'm probably going to get a better radio anyways but i will check the wiring and everything first
