my build thread
time to start a thread now so wil have a go loads of pics to up load so will start with some parts i have
IMG-20130714-00443.jpg the car 100% uk stock when i got it ,
  • Replies 442
  • Views 33.3k
IMG_4740.jpg/attach]
Edited by dan300zx
today it was sort the scuttles out full run down with wet and dry degreased warmed up with a fan heater. then 3 coats of plastic primer followed by 6 thin coats of bumper black the out come was super looks brand me oem looking. has taken a few hours. before and after then some them its dry very happy with the out come.
Edited by dan300zx
and before i did them
getting the plenum ready for powder coat. its a spare on spend some time with the wire wheel on the drill then a de grease. will drop in off to moz deleted all the crap on the under side, to
[ATTACH=CONFIG]95572[/ATTACH]
[ATTACH=CONFIG]95571[/ATTACH]
[ATTACH=CONFIG]95573[/ATTACH]
Get them threads and bolt holes on that plenum protected Dan with nuts and bolts (old ones) or you will be in for a life of pain putting it back on:cursing:
funny you say that i have been digging in that bag of bolts you gave me last year and have a load ready to do just that
throttle body stripped a cleaned looking nice you can see what i looked like before and after and the joining bar.
new drivers side wing here at long last only taken 3 months for nissan to get there arse into gear. IMG_4794[1].jpg
[ATTACH=CONFIG]95614[/ATTACH]
[ATTACH=CONFIG]95615[/ATTACH]
[ATTACH=CONFIG]95616[/ATTACH]
What did you use to clean them up with Dan??
Very nice, long time since I have seen a brand new wing! I'm curious, what sort of packaging was it sent in?
not sure as it was repacked at mike its a genuine nissin wing like so i have both sides now brand new
got the system 3 inch polished up came up nice before and after pic left polished one just done IMG_4795.jpg
think the pair was about £500 ish maybe a bit less
Quite pricey then, might look for some for mine next year.
yes the bills are racking up fast. but all the 2nd ones are junk
the drivers side arch have a little rust on the edge so i had a new arch welded in went down to the spray shop today so i could role and flair the arch to match the other side i did a few weeks ago, was there for 3 hours bit of a pain a role is pretty easy but a flair it a lot more work, few pics of it IMG_4813.jpg
A lot of work has been done Dan :thumbup1: and I see another electric aerial has been deleted.
am doing all i can now gary. yes ist done also the rear wiper to, i have the maifold and cam covers and other parts in power coat now to. and other parts om the way.
dont think i will be going ,when ive done this a going to restore a old motobike the one i have my eye on is from 1937
more work done wheel arch plastic has taken 4 hours to do this, i could have get new ones but i like refurbing what i can as its not cracked the under try is so new a new one of then and fan shroud. were is what a did and before and after pics. or fairy washing up in red hot water scrubbed the life out them. rinsed. then in used tar removed and scrubbed again then some kitchen work top cleaner, then 7 coats of maguiars untimate protection trim restore letting each coat dry and warmed by the fan heater the after shots are not wet by the way there dry and finished hope you like
Jeez !! A lot of scrubbing done there buddy, I'd say your arms are tired:yes: Great job though:thumbup:
