JDM 300zx 1995 LIMP mode problem
Hi all my 300zx fans.
My name is Dave from the Netherlands.
Recently I imported a 300ZX ( Fairlady Z Z32 ) from japan, and it will be fully restored.
But it seems to be in Limp mode, it will not rev above 2500 rpm's.
I alreayd replaced the MAF and that seems to work good. And did a lot of research but I just can not get it out of limp mode.
I also tested the ACC mode 2 and tested the o2 sensors, they dont seem to work, so both lambda's will be replaced.
I get the following error codes, can you guys seem to guess what the error codes mean:
https://www.youtube.com/watch?v=vXreJ6jdHsM&feature=youtu.be
Thanks in advance for all the help.
I really hope to get this fixed, because i has been taking me months now, and I'm slowly turning gray :'(
Greetings,
Dave
  • Replies 34
  • Views 5.3k
Not a big fan of that to be honest. Might kill the engine...
Did anyone on this forum ever try it, and succeeded?
Hi dave, I have just done the det sensor mod with the resistor and it works fine. I am planning to replace the sensor but mount it at the rear of the plenum. It isn't as effective there but it's definitely better than having none at all.
If you search youtube you will see that the det sensor can be relocated to the rear plenum bolts.
Good luck..
Was good to see you Dave and I'm glad I could help you get the car running correctly.
Now quickly get that bodywork/interior/painting sorted (before spring), so you can experience the Zed experience !
-Eric
I want to get it done before spring indeed, but if that might fail ( because I want this car in mint condition ) I can always use one of my two rx7's or my s14a :)
Thanks for all the help guys, the Z community is way better compared to the skyline or silvia guys.
12250181_725168414284389_6546341282381944031_n.jpg?oh=1dae37fe8185da847a602e2cd56c581e&oe=57393117
-Eric
Thanks for helping out a fellow Z32 owner Eric. You are a great asset to our community.
