Does my car have cats?
I'm amateur but not a noob, and I'm pretty sure something ain't right.
Took my exhaust off to do some other work (1990 Z32 TT), and I couldn't help but notice there are no cats on the underside of the car. But fair enough, I've fixed cars before with cars in the engine bay.
But then I saw replacement exhausts etc and they all had the cats on the underside of the 300zx, so I followed my pipework and I know where the lambda sensors are (right behind the engine bay) but as far as I can tell, I can't see cats? My car had its exhaust system replaced in 1998 immediately after the last owner purchased it, and I have receipts every year for parts/MOTs since but none mention a decat, and none mention emission failures/advisories for MOTs - although perhaps they "knew a guy".
I have a some minor white smoke out my exhaust, but no bad smells of HCs or NO/NO2.
So.. is there something about the early Z32 emissions or TT model that means a cat isn't needed?
The last owner was into racing, fitted a custom cooling fan amongst a few other subtle mods..
Backbox & Midsection:
Mid to front section:
Split:
Split 2:
Split 3:
Engine bay with lambda sensor (corroded bit below the red wire)
Without cats a 300zx TT will still pass emission tests :thumbup1:
He probably deleted them to increase exhaust flow.
Was it 1991 or 1993 when there was a change in emission/cat laws?
But either way, thank ****, was dreading the thought of new cats hahah
No cats visible there. I think only USDM had precats.
uk cars had a pre cat to
Any z registered before August 1995 does not have a cat test done during mot.
