I am using Kawa IDE to program Java, but its been so long since I used it last I have forgotten how to configure it.
You have to set the bin and lib directories to the JDK directories but I can not remember where the JDK source path is. Can any one help or am I over peoples head here ;)
Stuart
F**K Me!!
what are you smokin' M8?
F.T.
Sorry man,
C++ is as far as I go.
Must be my lack of IT skills next to other Zeddies.
Anyone else here apart from me a involved with cmemistry? Or am I the only mad lab coat wearer among us?
IT??
I had a cousin called that!
(Cousin IT,Adams family.......keep up,please!)
F.T.
Do you mean the environment variables for the JRE?
You can set up the Java Class path environment variable normally called JAVA_HOME there.
Goto System Properties | Advanced | Environment Variables.
Hope this helps.
Martin
Sorry mate I haven't used Kawa IDE.
I use J2E myself. But if it's the same we also use Java_Home as the main variable path for bin and lib dir's.
I have a dual boot and I wanted the Win2000 boot just programming so I can keep it all seperate.
I installed on 2000 and it didnt work so I went to XP and installed it and it works fine :confused:
