Nissan spec
FSM states:
Front:
Camber (degrees): - 1deg 35' to -0 deg 05'
Caster (degrees): 9 deg 00' to 10 deg 30'
Toe-in (mm): 0 - 2
Total toe-in angle (degrees): 0' - 11'
Kingpin inclination (degrees): 12 deg 10' - 13 deg 40'
Rear:
Camber (degrees): -1 deg 35' to -0 deg 35'
Toe-in (mm): 0 - 4
Total toe-in angle (degrees): 0' - 22'
FSM states:
Front:
Toe-in (mm): 0 - 2
Rear:
Toe-in (mm): 0 - 4
Are there any differences with or without HICAS, or between JDM and European spec?
Thanks much appreciated had my wheel alignment done and just doesn't feel stable so ill use these settings.
