ECU question
Hi
I had a nistune board fitted and tuned to my auto TT. When taking out the standard ecu we saw it had been changed at some point to a manual ecu, the tuner said it shouldn't be a problem for the gearbox as the 300 has a seperate ecu for it, is this true?
I don't seem to have any issues with abrupt changes or the like, maybe just shift points seem to take a bit longer than i would expect but as this is my first 300 and auto i don't relly know how it should feel.
Ben
Didn't know a manual ECU would work in an auto O.O
They're interchangeable. I'm not sure on the actual map of the chip, but they'll run just fine.
Ok thanks, i was guessing the same as i dont seem to have any issues. Was just wondering about the auto cars having a seperate ecu controlling gear changes etc.
Auto boxes does have a separate ecu. Auto ecu will work on manual and auto. But not manual on auto
my impression is that an ENGINE control unit does not interfere with the gear system. so i would agree with Si :)
Well as an unwitting test subject :) it does seem to work fine........
No difference whatsoever as far as the hardware is concerned.
