ECU question
Hi
ย
I had a nistune board fitted and tuned to my auto TT. When taking out the standard ecu we saw it had been changed at some point to a manual ecu, the tuner said it shouldn't be a problem for the gearbox as the 300 has a seperate ecu for it, is this true?
I don't seem to have any issues with abrupt changes or the like, maybe just shift points seem to take a bit longer than i would expect but as this is my first 300 and auto i don't relly know how it should feel.
ย
Ben
Didn't know a manual ECU would work in an auto O.O
They're interchangeable. I'm not sure on the actual map of the chip, but they'll run just fine.
Ok thanks, i was guessing the same as i dont seem to have any issues. Was just wondering about the auto cars having a seperate ecu controlling gear changes etc.
Auto boxes does have a separate ecu. Auto ecu will work on manual and auto. But not manual on auto
ย
ย
my impression is that an ENGINE control unit does not interfere with the gear system. so i would agree with Si :)
Well as an unwitting test subject :) it does seem to work fine........
No difference whatsoever as far as the hardware is concerned.
