Wiring
Took the Z to an auto-electrician yesterday to get them to give all the under-bonnet wiring the once over, paying special attention to the throttle pos sensor, ptu, coils, etc etc,
What a difference it has made, nice even tick over, seems to be more crisp aswell. It was something I had been putting off for ages but glad I got round to doing it, and not too much money either as its all labour and about 10p parts.
Ahhh, lovely.
Hi James,
Wouldn;t mind this guy checking mine over as well.
an you give me some more info ?. Location, cost time taken etc ?
not being funny, but these are all things that can be done by anyone with even a glimer of DIY skills!! (no need for angle grinders here stu!! :D )
Hmmm, when it comes to electrics, unless its something obvious, I generally leave well alone. And the more important factor is I haven't got the time, or a garage or or or or....... so I booked it in to the pro's at this stuff. I presume you can make up little looms, have access to switches, plugs, connectors, heat shrink etc and somewhere dry to do it all.
They had my car for half a day, alot of the connectors were just so brittle they were snapping off and crumbling to bits, luckily they had others that could be used. The bill came to about £130 but some of that was to fix a problem with my horn.
The co. is called METROLEC, in BECKENHAM, a landmark very near is the Crystal Palace tower. Their number is 020 8650 5363. Say James put you their way if you don't mind.
12 years ago when I was 18 I had a Ren5 gt turbo and had an under bonnet fire, it went to them and just couldn't believe what they did and have been going back since.
James.
I have to sort of agree with Paul here. It's something you should learn to do yourself. I personally clean and lubricate all the contacts at least once a year. The problem with the heat under the bonnet can cause nightmares as well as connectors coming loose, so it gives you the chance to check them all over...............
I thought the bill would be more than £130 for a good auto electician, so that sounds like a good place to go if you don't want to D.I.Y.
Vijay
You're right, but some bits that I could see needed attention looked so fiddley -I just couldn't be bothered to get annoyed starting to do it. I have given my Z 100's of hours and this time thought I would let someone else do it!!
Sounds good to me, in my new found spirit of DIY car-bodging, I'll have to give it a go! Gotta get through my first ICE install yet though!!
Cheers,
Russ.
