Hi all.
Fairly sure the 20 year old induction hose from the air filter to the turbo is getting on a bit now and possibly sucking in a little at higher revs. Does anyone know if there is an aftermarket silicone hose or hardpipe kit available for this?
I saw one on ebay a bit ago now. It was a red silicon one. Looked good to be honest. But I have only ever seen one. Keep your eyes peeled aha
Ah no problem. Did look on ebay and rhe usual 300zx sites but couldnt find anything.
Might be a fine excuse to go dual maf once i save money a bit
I assume you mean the accordion pipe, the hard plastic/rubber one that runs from down by the headlight to the turbo? Fairly sure Z1 sell silicone replacements. Have you tested it to see if it leaks? It's a pretty robust pipe compared to most of the rest. I'd check you need one first, it's more likely the hose clamp isn't secure enough.
