I am after a good condition rear transmission mount urgently....
I have tried MJP but there is a 3 week wait and I need to get the transmission back in the car......
Russ
I've got a good one Russ.. Removed and ready to go so can be with you this week. £25 delivered
Hi Baz, thanks for the offer mate.... But have made the hard decision to lay up the Z for a while and focus on stripping off absolutely everything on the suspension, brakes, diff, subframe, etc....
I am on a powder coating, polishing, painting and cleaning mission......
I realised I am not going to make a single show this year and have lost the mojo after 2 days of everything going wrong that could go wrong......
Finally swapped the auto box on my own and then found the torque converter had moved and was no longer engaged on the 2 oil pump lugs...... after I torqued up everything...... engine is locked and won't turn over.....
Pulling the box out again friday..... back at work monday so no time to get ready for JAE.......
Thanks again Baz......
Russ
Pretty sure the same mount is used on skylines and Silvia's. The nismo mount is interchangeable and easily available so might be work looking up.
Ordered the Nismo one and promised here by 20th..... Cheers Stephen, hadn't thought about Nismo version.:thumbup:
