RichardS ·
After a spankin' new set of boots 900 miles ago, I'm ready for more. (rear that is).
And after a long conversation with Andy Duff,
(cheers mate). :-)
It seems even Bye eye the toe in is miles out!
I can knock up a jig with a 48" vernier guage to measure the differance! & correct by perhaps dividing the inclusion x 4 !
Is this correct are the wheels absolute parralel on draft (sides)
Can 'Kwick Zit' & such do a satisfactory job or do I 'ave a go.
Experiences welcome.
harve.
