Clutch master cylinder
I have a 91 non turbo, the clutch master cylinder has gone, would a twin turbo of the same year fit. Many thanks people
I have a strong feeling you can't interchange the two. The TTs have a booster and that changes things. Just incase you weren't aware there are two bleed nipples on the clutch from factory, one on the slave and one near the headlight. It's a notorious pain in the ass to bleed. Rebuild kits are available for TT clutch masters which is what I did with success, so that's worth a shot. Have you had your clutch replaced now?
Pretty sure you can buy the na one from any car part shop, the na has a linkage attached that goes to the pedal the tt has a servo...
I have a tt When mine failed I got one from partshop which turned up with the linkage, I needed mine desperate so I took the seals out and used them in mine...
