Coolant system.
ย
I am curious. i am looking at repositioning my overflow bottle and getting a smaller one. Does the bottle need to be vented ?
on the existing tank there is a hole just below the screw cap. is this necessary ?
ย
most off the over flow tanks i have been looking at do not have a vent hole
I got rid of the OEM tank as it fouled on my larger IC's. I bought a kit from CZP that is basically a small plastic bottle that fits on to the IC fixing mounting point, it is vented by a small clear tube that has a stopper at the end, however just before the stopper there is a small hole in the tube so should the water need to escape/vent it does so through this small hole.
ย
Before I ran this I had no expansion tank and the water in the radiator would always escape through vent pipe onto the ground, since running this, water level always remains constant.
ย
https://conceptzperformance.com/Cart/description.php?II=3851
ย
Hope this helps?
