Got a few posts to do to get some opinions, here's the first...
My trolley jack (3 foot long) has got a problem, when jacking up the front or rear, does about 2-3 strokes with full lift, then the arm just goes about 70 degrees with no lift or back pressure and then only in the last 20 deg does it try to lift. this then carries on like this. My local parts store says its low on oil and needs topping up , but must only use "non foaming jack oil" which is not in, and he says it may only need a thimble full,
Is this a fair diagnostic, and is he right about this jack oil, could I use "tool oil" which I use on my oil tools?
Any opinions gratefully.... you know the rest...
Rich
