Blocked fuel vent?
Filled the car up there for the first time, however when I removed the filler cap there was a huge release of pressure. The pump then kept shutting off, so it took about five minutes to put in twenty liters or so. It could still be filled at a slow rate and drives fine.
Is there anything in particular that could cause this problem or should I just follow the usual route of investigation?
mine does that sometimes........ don't push the nozzle in so far and twist it to side a bit...... then she fills okay........ I think it is the pipe angle to the tank........ lol
If not then I have had the same problem since 2001...... lol
I've got the hang of it now by not fully inserting the nozzle. Only concern is, if I fill the tank will the nozzle still be able to shut off automatically?
mine does........ well it did the last time I filled her right up........ that was a while ago......... lol
