15mm Hubcentric wheel spacers
As per title guys & girls after a pair or 2 pairs of Hubcentric wheel spacers preferably 15mm but may consider others.
ย
James
I don't think many companies make them as small as 15mm, as the nuts/threads from the hub protrude and foul your wheel. So check the layout of the Hubface of your wheel, you may not be able to use them. I have a set of eibach ones but they are currently not for sale and likely won't be for a while yet.
I have a pair of 10mm and 15mm with longer studs in the garage. Stay away from bolt on 15mm, known for breaking...
ย
I heard something similar myself, but IIRC it was the cheap and nasty copies that had the problem. The likes of quality spacers from Eibach are much stronger and shouldn't have the same problem.
IIRC the example I heard about involved the proper weapon that is the GTR R35 and a track day. If anything is going to break a spacer that combo is!
