Help, MOT fail
Hi all, i just had a re test today and it has fail again on emissions, drivers side, lamba sensor 1.05, anything over 1.03 is a fail,
I only have till 7pm today to get it through, its with my mechanic, any ideas to get it down quickly,
  • Replies 31
  • Views 2.2k
A small leak in the exhaust can cause a high lambda reading, the Venturi effect draws air into the exhaust upstream of the test probe. A tiny leak can and will cause this.
Also in the uk, if an exhaust is joined anywhere post engine you CANNOT test each bank individually.
no full RETEST because of .02 i am actually drunk now, you guys are so good, thanks all especially Graham, you old palx
i meant NO it failed I need a full RETEST, told you I was drunk
