Cone air filter
Does anything on the car need changing if I put a Cone style air filter instead of the stock ones?
Some told me that you should change the timing slightly! Is this true.
Changed my filters a few days ago and the old ones where covered in crap, the person I bought it of a few months ago hadn't changed them for a very long time. The car ran so much better when clean ones where put.
Does a cone filter make it even better?
Stuart.
Never heard that before..
The intake has nothing to do with the timing.
Changing the timing from stock (15degrees) can have a performance increase, but it also increases the risk on detonation.
So this is NOT recommended..
A conefilter will sure make difference from the stock airbox...
You'll probably have to remove the headlamp-washer reservoir though..otherwise the cone won't fit.
Do a search on *intake*...it has been discussed many times...(also which filters are available and recommended)
-Eric
http://300zx-twinturbo.com
