- Replies 69
- Views 1.8k
- Created
- Last Reply
StuartTheFish 15 posts
ruishy1 8 posts
EvoluZion3 7 posts
Mondo 7 posts
It is with heavy heart that I am putting my Z of over 12 years' ownership up for sale. I have had many great times with this car but I am thinking of consolidating my two cars down to one as I have less time to give the Z the care and respect it needs, and am looking for something more modern and practical. The Z is overall in very good shape but I have listed all the bad points I can think of below. There's tonnes of service history, receipts, and all MOT certificates since ownership are included.
SPEC
Series 1, Japanese Import, LWB, myself the only private UK owner, Twin Turbo, Targa Top, Manual [converted from automatic], originally gunmetal grey.
All usual UK-conversions done, like UK speedo, rear fogs, delimiter.
G587 TVO
MOT: expires 14th May 2015
MILEAGE: 142k miles
Located in Leicester
SERVICE HISTORY
All receipts for work carried out, many receipts for parts and modifications, and all MOTs are available dating back to start of ownership.
GOOD POINTS
The bodywork is largely in very good condition after having a respray in 2005 and a new bodykit in 2009 - the occasional stone chip or light scratch does little to detract from this.
Brand new windscreen in 2008.
New battery has barely done 1,000 miles.
The interior is mainly in very good condition after having the seats and dash/door cards retrimmed in 2009/2010. Some other parts of trim are looking a bit tired and need re-gluing, and there's a smallish tear on driver's seat.
The suspension all round, and front brakes are all aftermarket and have only done a couple of thousand miles or so since fitment.
The engine is a very good runner and pulls especially well in 3rd and 4th gears, partly thanks to the N/A Differential modification. Just the occasional whiff of blue smoke on overrun after hard boost due to suspected PCV valves being slightly different spec (replaced in 2007).
The engine and turbos were rebuilt in 2007.
Car only covered on average 3,000 miles per year under current ownership.
BAD POINTS
Electrics are in generally good condition, but after standing for about a week with no use the battery will not start the car. Also gives
Windscreen demist works intermittently (either perfectly or not at all!)
Boost controller is in working order but suspect there may be a fault or electrical short - possibly causing the above (I was planning on going with a manual boost controller).
Front nearside tyre can scrub briefly on the inside when taking hard bumps/corners fast due to width of front tyre (I was planning on going down to 235 from 245).
Exhaust body chirps at times when cornering hard left (catching on something underneath?)
Cruise control never worked (I've never been bothered!).
Small patch of paint bubbling near offside rear wheel.
The three aftermarket gauges are out of order (oil press. never been hooked up, and the needles of the other two have snapped over time).
Front washer motor needs replacing (replacement included with sale but not been tested).
As with a lot of targa tops a bit of rain manages to get in and drip onto either passenger or driver seat. I cover the Z up when a lot of rain is expected.
Running temps can get high when stuck in traffic for a while on a hot day (possibly due to removal of fan shroud).
Rusty sills - driver's side is very bad particularly at the rear. Passenger's side isn't too bad and can be jacked up using the standard roadside jack. Some bad rust at the offside-rear corner behind the rear bumper. Also two holes either side of the boot floor.
MODIFICATIONS
Bodywork
Colour change to 19H Mazda Atlantic Blue
Wings West Bumper
Stillen Louvred Headlight Panel
Viper rear spoiler
Veilside C2 blended sideskirts
De-suaged doors
Z-Centre mk.2 bonnet vent blended and cut into bonnet
Smoked black side repeaters
Crystal Clear front indicators
Fog-light ducts
Blue illuminated rear panel
99-spec rear lights
Smoked rear reflectors
HIDs
Rear wiper removed
Smoothed (de-mottled) rear bumper
Carbon fibre B-pillar covers
19" Cruise 136 alloys
Nexen 3000 Tyres (275 rear/245 front)
Engine
2990cc Engine rebuild
Wiseco 87.5mm forged pistons
Cometic head gasket
DeatschWerks Highflow Pintleless 555cc injectors
TurboNOS chip & tune
360 degree ballbearing turbo rebuild
AMS stage 4 3" Expansion split downpipes
Labree 3" decats
Labree 3" full exhaust system
ApexI Powerflow intake
GReddy Profec E-01 boost controller
JWT Flywheel
Z1 Motorsport sidemount intercoolers
Koyo radiator
ApexI Super-AFC2
ApexI Twin-Chamber BOVs
SGP lightweight underdrive crank pulley
Manual cams
Series 2 PTU
Relocated PTU near to air filter
NGK Spark plugs
Plenum water bypass
Hardpipe intake kit
Stainless steel rad pipes
Engine bay electrical grounding kit
Nismo oil cap
Nismo radiator cap
Braided fuel line kit
AIV removed
EGR bypassed
Transmission/Drivetrain
Auto->Manual conversion
Hybrid T/T -> N/A Single-piece lightweight propshaft
N/A Subframe
R200 Differential
RPS Organic Sport Clutch
SGP Uprated Pivot Ball
SGP Uprated Braided Clutch Line
Short-shift gearlever
Nismo Gearknob
Suspension
KYB AGX shocks
Eibach pro springs (20mm drop)
Powertrix front upper arms
Powertrix rear upper arms
Powertrix front tension rod
Brakes
K-sport Black 8-piston brake calipers (front only)
K-sport 330mm vented and slotted brake discs (front only)
High-performance brake lines (front only)
Interior / Misc.
Black/blue Vytex seat retrim with Z logo
Electric blue interior panel trim kit
Chrome dashboard rings
Colour-change silver-face indiglo dials
LED dash control pods
Triple A-pillar pod
F&F Boost Gauge *
F&F Oil Pressure Gauge *
F&F Water Temp. Gauge *
Side quarter privacy glass
ApexI Turbo Timer
ApexI RSM
ApexI G-Force Sensor
Option Tuning steering wheel
Carbon-fibre forward dash vents
Nismo gearshift gaitor
"300ZX Turbo" handbrake gaitor
TOAD ai606
HISTORY
Check the 300ZX.CO.UK journal here for other details of modifications/history/etc.
OTHER STUFF INCLUDED FREE WITH SALE (I'd rather these just went with the car as opposed to selling & posting out individually)
Spare key and alarm fob
4 x Z DVDs
300ZX.CO.UK shirt (L), hoodie (L) and 25th anniversary T-shirt (L)
Canvas print [of the car but with its old bodykit]
A3 print [of the car with its current bodykit]
Z Mug [unused]
Z Diecast model
Z Coolart picture
5 x Z Club magazines
Spare bottle of blue paint (correct colour for bodywork)
Spare reg plates
Bag of misc. spare fuses and relays
Replacement front washer jet motor (untested)
Replacement front wiper motors (untested)
Spare stock driver's-side sun visor (boost controller currently sits in a modified sun visor)
I know it wouldn't be up to me but I'd really like to see her enjoying the road for a while to come and not broken up for spares and aftermarket parts. Bearing in mind the MOT is about to expire I'm happy to let her go for far lower than I'd have wanted for her perhaps a few years ago, even though she's barely done 1,000 miles since passing the last MOT, and so I'm looking for £2,600 o.v.n.o. Please PM me if you're interested or have any questions.
[video=youtube;sB-OVas0kGg]
[video=youtube;-YpoZdvKdqQ]
Edited by EvoluZion3
