Turbo oil and water lines
Ok iv got these oil and water line image.jpg anyone used them or got any photo on fitting and routing
I have looked at these myself but not used them so this is just logical thought. The double male threaded ones are for the oil feed. The four banjo ones and bolts with holes are for the water feeds on the turbo core. The barbed ones must be to go from the braided water hose to the normal water hoses.
The good thing about the stock configuration is that hard portion means you know it's not going to be testing on the exhaust housing, you have no control of this with the flexi ones, particularly the water ones. The advantage of them is that you don't have to fight with the oil feed hard pipe and I suspect it's easier re tighten that configuration. For me I was thinking il only use the oil feeds and leave the water ones as nature intended.
