Targa trim removeal
How the best wat too remove the targa trim as I want too but new ones after the respray
Which ones are you talking about? The ones on the panels or the ones on the body?
Ok. You can pull them off, but there's likely hood of damage. The best way is to strip the targas and unscrew the retaining clips from inside. If you're going in for a respray then you're best off stripping them all out anyway. Means you'll avoid overspray on the seals etc.
Cheers si I'll have a go on them
Theres two in your pic.the bending ones are the window ones. To get these of without damaging anything first remove the targa roof panles. Then at th top ot the windscreen the first clip carfully put a tgin scrapper underneath and give it a slight tap towards you way from the screen.once you have that top clip broking free you should be able to slid again up to the top of the screen the whole strip without bending it.thats the same for fitting back on only the reverse and use new clips .cheap as chips.
Another tip that has worked time and time again for me is to soak the trim and retaining clip area with silicone spray or WD40 lubricant and slide away!
Cheers guys can't beat a bit of lubricant Tony how are yea bud all good I hope
You and your lube a tony?
