- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
I am going to use this is a bit of a diary of this issue so I can keep track, as well as hopefully hear some thoughts..
Generally car runs beautifully with no issues, with an intermittent stalling/fuelling issue which I would like to keep an eye on
Issue started 3 months ago. Stalled turning out of my road when I put the clutch down, and wouldnt' start again for a couple of mins. Then fine for another months.
Second occurrence a month later - Motorway in 4th gear - Foot down to overtake and power cuts out completely. Put clutch in and engine stalls (traveling 60mph). Clutch back out to bump start engine again and all power was resumed. No issues there after.
third occurrence 1 month later (this week). I start engine after work and release key a bit too early (usually starts instantly). It then refuses to fire and just turns over without firing at all, Leave it off for 3 minutes, try again and fires up first time straight away.
forth occurrence today. In the garage from a cold start I turn key and start it and straight away is lumpy as hell with revs dropping down and stalls. pressing accelerator didn't make any difference to revs. Then starts straight away and is fine after leaving it for 20 seconds.
So, My wondering....
- Fuel Pump related?... Weak pump causing issues? I am trying to leave the key in position 2 before cranking it each morning to see if that helps the starting issue (does that prime the fuel pump or am I talking rubbish? - Think I heard it somewhere as you get a noise from the rear of teh car for a few seconds when in that position ).
- MAF sensor has intermittent fault/failure.
- ECU has an issue?
Beyond this I am hoping that it wouldn't be anything more catastrophic? Engine is sweet rest of the time with no loss of power at all. Any ideas appreciated!
